 Post subject: 69 camaro and bbc stuff
PostPosted: Sun Apr 24, 2011 10:45 pm
Pair of front white houndstooth bucket seats and rear seat for coupe 1969 camaro. need recoverng. Tracks and frames appaer very good. $400
Pair of black standaard buckets for 1969 camaro. need recaovering. Frames and tracks in fair condition need recovering/restoration. $200
Pair of white aftermarket oer brand headrests 69 camaro new in box $180
Pair of white seat backrests 69 camaro new in box oer brand $75
Set of yellow 1969 camaro hard to find rare rare rare front and raer door panels...with trim embelms filler piece behind door latch arae and yellow windlaces!!!!(door panles really only good for trim and parts only windlaces and door panle cups not shown in pictures but are as good as can be found.$800
set of 69 camaro steel upper front and rear standard door panel pieces. these are what you need to complete a set of door panles that come unassembled. $60
Set of black front and rear 69 camaro comfortweave upholstery new in box $225
set of white standard used standard front and rear uppolstery...driver quality $40
2 69 camaro column shift steering colums one blue one black. $80 total for both
69 camaro forward lamp harness with guages ..new in package MH # wr13005
Pair of never installed in car(dyno time only) hedman hustler race headers for bbc 69 camaro. 2 1/8 inch white ceramic coating great condition. $600
Mickey williams custom bbc aluminum oil pan for stock cahssis 69 camaro 8 inch deep sump with kickouts. new never used...$700 new ...$600
074 aluminum bbc zl1 l88 heads ported pressure tested brand new never manlye severe duty valves,new seats and guides, factory rebuilt jesel shaft rockers and tig welded one pice rocker stands, rocker geometry set up....2 -2.2 inch valve springh height no problem....flow sheet available...$2000 complete
zl1 053 2003 vintage chevy bbc block. needs repair. crack in numebr 6/8 wall. can be fixed. total cost including welding to repair and install 8 new sleeves rehone etc...$2000.... sell block for $1100 shipped in gm crate.............<<<<<<<<<<<<<<<<<<<<<< zl1 block SOLD >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
Brand new auto meter ultimate II playback tach 6881 5 inch 9000 rpm...back of box opened to remove instaructions tach never out of box ..included...jegs $765... sell for $650
assembly manual 1971 camaro $15
full helms shop manual set for 1998 camaro $80
timing cover steel original bbc $20
please email with questions,
Thanks
Ryan
