It is currently Sun Jul 06, 2025 10:34 am
 Post subject: BBC exhaust manifolds: extrude hone or jet hot coat in/out
PostPosted: Tue Nov 13, 2018 12:58 pm
Thoughts on what would help more...extrude hone or jet hot coat in/out or both?
1970 SS454 LS6
 Post subject: Re: BBC exhaust manifolds: extrude hone or jet hot coat in/out
PostPosted: Tue Nov 13, 2018 5:27 pm
Mine are stock replacements opened up some, nothing fancy
PostPosted: Tue Nov 13, 2018 5:44 pm
Personally I don’t think extrude hone is worth it, but I do believe in ceramic coating exhaust manifolds. Anything to keep heat out of the engine compartment.
PostPosted: Tue Nov 13, 2018 8:27 pm
HPC Coating works, Send them to Gene in East Hartford, Extrude hone does nothing and is a waste of money.
PostPosted: Wed Nov 14, 2018 8:41 am
Thank you,good to know. I have stock replacements as well. Untouched, out of the box. Was thinking removing the "bumps" on the inside that are for the AIR fittings might help.
That is what I heard as well and appreciate the confirmation. I will also get in touch with Gene-thank you!
1970 SS454 LS6
PostPosted: Thu Nov 15, 2018 5:18 pm
Ralph, is this the place?
http://www.centralctcoatings.com/index.html
PostPosted: Fri Nov 16, 2018 12:51 am
Yes make sure you tell him you are with SuperCars.
