It is currently Sun Jul 06, 2025 2:42 pm
 Post subject: CT DRAGWAY REUNION TONIGHT
PostPosted: Mon Jun 22, 2015 8:04 am
In Meriden.
 Post subject: Re: CT DRAGWAY REUNION TONIGHT
PostPosted: Mon Jun 22, 2015 11:08 am
actually at the Mountain Ridge Resort at the top of High Hill in Wallingford.
I will be there!! :aok
1970 SS454 LS6
PostPosted: Tue Jun 23, 2015 10:04 am
anyone know what total count was for attendance last night?
Hal,I love your 69 SS427 Impala..that is one sweet ride :aok
1970 SS454 LS6
PostPosted: Tue Jun 23, 2015 12:29 pm
Sharleen said 790 cars :bow
PostPosted: Tue Jun 23, 2015 2:34 pm
Last night was my 18th consecutive year of attendance..time sure flies
1970 SS454 LS6
PostPosted: Tue Jun 23, 2015 3:10 pm
Thanks, Boy, my legs were pretty tired by the time I got home. Heavy clutch and nasty cam, two springs on the throttle return. Drove the country route back to Salem.
PostPosted: Tue Jun 23, 2015 4:37 pm
Hal,what does the SS427 have for gears? I noticed the mid 12 ET :aok
1970 SS454 LS6
PostPosted: Wed Jun 24, 2015 4:52 pm
Chris, Blackie lead a secondary life for a number of years. In the mid 70's I built it into a serious for its time Stock Eliminator car. Took off everything I could unbolt got the weight down to 4050 lbs. Built a .060 over 427 with blueprinted heads, forged pistons, low tension rings, Lunati cam, L-88 crank. Ran 4:88 gears and a wide ratio Muncie to get it moving. Rules back then dictated 9" tires and no electric fuel pump. The car ran in F/S on an index of 12.55 and the car ran right on the index. In 1979 (I believe) the rules changed to allow an electric pump which really helped the big block GM cars with Q-jets. The rules also changed to require a roll bar down to F/S and naturally the Index dropped.
I had no interest in cutting anything on the car so out went the race motor, tranny and gears. I put the Original numbers matching set-up back in with a small cam, along with all the other stuff I took out. I got my big tire Nova about then and Blackie sat in the garage a lot. About 10 years ago I made some passes as you saw it Monday with original 3:55 gears and it ran 13.70s. The only thing left is to reinstall the stock exhaust manifolds and A/C which maybe I'll get to some day.
PostPosted: Thu Jun 25, 2015 6:22 am
Hal,I appreciate you sharing some history of your SS427..what a neat car,have always admired it. :aok
1970 SS454 LS6
PostPosted: Sun Jun 28, 2015 8:16 am
Ho my God did I read it right 790 cars fantastic :hpbd :hpbd :hpbd :USA
Users browsing this forum: No registered users and 11 guests
