It is currently Sun Jul 06, 2025 2:49 pm
Post new topic Reply to topic  [ 428 posts ]  Go to page 1, 2, 3, 4, 5 ... 29  Next
 Post subject: MuscleCar Trivia 1957 to 1974
PostPosted: Fri Apr 26, 2013 10:18 am
I will post a 1957 to 1974 MuscleCar Trivia Question once we get the right answer I will post another one. Are you Ready?
 Post subject: Re: MuscleCar Trivia
PostPosted: Fri Apr 26, 2013 10:19 am
What musclecar(s), when delivered to the dealer, came with factory installed tubular headers?
PostPosted: Fri Apr 26, 2013 10:21 am
D dart
PostPosted: Fri Apr 26, 2013 10:23 am
Rhett Incorrect
 Post subject: Re: MuscleCar Trivia 1957 to 1974
PostPosted: Fri Apr 26, 2013 10:30 am
The D-Dart did have (2) unneeded items removed from the car. (1) The radio and (2) the center console unit that was typical on the Dart GT's.
The car did come with the heater installed, and the inlet and outlet hoses were connected to their ports, mounted on the passenger side of the firewall. Most racers just disconnected the hoses, and several (if not 80%) removed the heater unit (about 18 lbs. of weight) from the car.
Basic 6.95 x 14" 2-ply tires were used, mounted on 4.5" wide steel wheels, with the 5-bolt 4" bolt pattern (commonly called the A-body wheels).
Doug Headers. Street-type non-fenderwell units that went down the sides of the engine compartment and under the chassis. The headers have 1 5/8 tubes. The collector is about 2 7/8" ID -- a wierd size. The factory y-pipe is 2 1/2". These dimensions are from a surviving set of headers today.
Because it came without warrenty? Not shipped in the trunk, but installed. Or because it's a dart! WHAT NO LOVE FOR A BODIES! :moon :moon :pop
PostPosted: Fri Apr 26, 2013 10:33 am
The D-Dart headers were not delivered to the dealer installed. They came in the trunk. Try again.
PostPosted: Fri Apr 26, 2013 10:38 am
1) The car was a standard Dart GT model, but with high performance options installed at the factory. The rated horsepower was 275, compared to the 235HP of the standard high performance engine option. The differences included a Holley 4160 carb., CamCraft 284 degree Camshaft, Racer Brown valve springs, low restriction air cleaner, and a Weber clutch. Also they used the 8 3/4" Sure-Grip rear end, Doug Headers, 4 speed transmission, heavy duty suspension, and 6.95x14 BSW tires. :shrug :pop
PostPosted: Fri Apr 26, 2013 10:40 am
1965 Shelby gt350 Mustang. :pop
PostPosted: Fri Apr 26, 2013 11:11 am
1964 Dodge Polara 426 Hemi. and Plymouth
1965 Dodge and Plymouth A990 cars
PostPosted: Fri Apr 26, 2013 11:18 am
Correct :winner
PostPosted: Fri Apr 26, 2013 11:20 am
In 1970 Plymouth C-Body were now available in the new "High Impact Colors". What High Impact colors could you get on the 1970 C-Body? :pop
PostPosted: Fri Apr 26, 2013 11:36 am
panther pink, plum crazy, sublime, go mango, hemi orange, top banana
PostPosted: Fri Apr 26, 2013 11:52 am
1964 came with cast iron manifolds for the first 2 inches or so. Then exhaust pype, but I would say that is Correct :winner
PostPosted: Fri Apr 26, 2013 11:54 am
Those are most of the High impact colors. But not all of them are listed and not all of them were available on the 1970 C-Body Try Again :pop
PostPosted: Fri Apr 26, 2013 2:29 pm
Plum Crazy - In Violet, Sublime, Green Go - Sassy Grass, Go Mango - Vitamin C, Butterscotch - Bahama Yellow, Panther Pink - Moulin Rouge, Hemi Orange - Tor Red, Top Banana - Lemon Twist.
