Post new topic Reply to topic  [ 22 posts ]  Go to page 1, 2  Next
 Post subject: 440 compression
PostPosted: Tue Apr 02, 2013 5:25 pm
Help, I have a 1967 440 that has 10.25:1 compression. The heads have not been milled and the block has not been decked. I am tired of using cam2 to just drive around and I am tired of the pinging. Timing has been set at 12 deg. btc. What can I do to lower compression to 9.25. Do not have alot of $ to spend. Thanks
 Post subject: Re: 440 compression
PostPosted: Tue Apr 02, 2013 5:32 pm
What size head gaskets are you running? Thicker head gasket=lower compression ratio
What is you total ignition timing? All in at what RPM?
You can try heavier springs on your mechanical advance in your distributor
PostPosted: Tue Apr 02, 2013 6:18 pm
10.25 is not very much compresion. Check your distributor make sure you don't have to much timing advance. What is your total timing when the distibutor is done fully advancing? Dial back the distributor.
PostPosted: Tue Apr 02, 2013 6:49 pm
Also check that your not too lean, or have a hot spot, such as a burr or burnt valve!
Detonation no good!
Also Run the coolest plugs you can get
PostPosted: Tue Apr 02, 2013 6:54 pm
:agree Mopar distributors have a reputation of a ton of vacuum advance. A company called 4 seconds flat sells distributors with custom curve and phasing for about $180 for your combination. No personal experience,but have only heard good things about them. :pop
PostPosted: Tue Apr 02, 2013 7:04 pm
Moparts website has some good information on the subject
http://Www.moparts.com
Once on the website, do the Google Custom Search :aok
Detonation 440 Mopar
PostPosted: Tue Apr 02, 2013 9:00 pm
I would be happy to swap my 83cc heads for your 73.5cc heads. It should get your compression down to 8.5 -1 and it will probably run OK on cow pee. But I don't think you have to. Just disconnect your vacuum advance and reduce your initial advance to zero or less if neccessary and see if the pinging goes away.
Then you will just have to work the advance back up as far as you can. As I think Shawn said it could be too lean. Try richening the jetting if the first suggestion doesn't work by itself.
PostPosted: Tue Apr 02, 2013 9:08 pm
Are you sure that your CR is actually 10.25:1? I run a 440 with about the same compression on 93 octane on the street with around 32-34 deg total advance and rarely have pinging except when the weather is really hot. I know first hand that my compression is just over 10:1 because I measured the combustion chamber volume, cylinder volume and compressed gasket volume and did the math. Good luck! :aok
Kevin
PostPosted: Tue Apr 02, 2013 10:04 pm
Or, Retard your cam!
Doing the hard stuff first is more fun! :mrgreen:
PostPosted: Tue Apr 02, 2013 10:05 pm
I've had the same issues that you are having. With the vacuum advance I was hitting 54 degrees and it was advancing to fast as well. I had Billy Atwood recurve the distributer (after trying a few other things) and it worked miracles. With an initial of 10-12 degrees and total in the 28-30 (mechanical timing) range my problems were solved with pump 93. No more pinging and sluggish bogging performance. My motor has 11.5.1 compression :bang Timing comes in a little later which is fine on the street.
PostPosted: Wed Apr 03, 2013 5:55 pm
Run tighter springs.. you may have to recurve the dist.???
1967 Plymouth Belvedere, GTX,
1968 Dodge (J code) HEMI 4Speed, Super Bee.
PostPosted: Wed Apr 03, 2013 8:45 pm
Thankyou for all the replies. I used stock mopar head gaskets,and a mallory unilite distributor. I use Champion RJ12-y PLugs, gapped at .040 with a Jacobs Mileage Master ignition. I think the total advance is 28-30,but not sure. The Holley carb was rebuilt to stock 440 specs. How about low compression 440 heads? To some this may be sacriledge, but I'm not too interested in going super fast anymore;just having fun and keeping the local law enforcement personnel away from me.
PostPosted: Wed Apr 03, 2013 9:30 pm
I would bet it has nothing to do with Compresion. Your in CT give Billy Atwood a call and let him take a look at it. I'm sure it will be cheeper than throwing parts at it and finding out in the end it was a simple fix.
PostPosted: Wed Apr 03, 2013 9:46 pm
Thankyou again. Who is Billy Atwood and how do I contact him?
PostPosted: Wed Apr 03, 2013 9:50 pm
Click the banner at the top of the page - Auto Service of Old Saybrook. If you don't see it, refresh the page until you do.
