 Post subject: Complete Dana 60 for B-Body
PostPosted: Fri Jan 11, 2013 9:43 pm
Just wondering if anyone has any recommendations for a Dana rear end for the super bee? I spoke with Doctor Diff on the phone today he seemed to be a nice guy to deal with, price for dana was about $1800 not including shipping from Montana.... Car currently has an 8 3/4 489 housing rear end in it, open non sure grip. He said that I would be better off just spending the extra few hundred bucks and going to a dana rather than beefing up the rear end I have in it, or putting a spool with 35 spline axles in it and limiting the street use significantly. Comments, advice or someone in the area to deal with would be great.
 Post subject: Re: Complete Dana 60 for B-Body
PostPosted: Sat Jan 12, 2013 11:35 am
The only reason to go with the Dana is to have the Bee look the part as an A12 clone. Your better of with the 8.75 rear. You won't break the 8.75. Also you have a better selection of gear ratios with the 8.75. Weight is also a big factor. Go with a 3.73 gear in a 8.75 rear or if your going to make this an all out drag car then 4.10 or 3.91 Ratio. I have a 3.73 in my Bnt Orange Road Runner and love it.
PostPosted: Sat Jan 12, 2013 4:28 pm
Thanks for the info Ralph ! Do you recommend using the power lock sure grip clutch unit that is available new? Axles?
PostPosted: Sat Jan 12, 2013 8:28 pm
Dr. diff is very nice to deal with, I bought a ring and pinion and yoke from him. The 8 3/4 is pretty strong. even with a four speed, the little tire doesn't really let you shock the rearend. To redo the 8 3/4 its about $400 for the new clutch limited slip,$80 in bearings,$200 in new ring and pinion,$40 crush sleeve eliminator, seals, if you can do it yourself its about $800. its been a couple of years but I think dr diff will put together a center section for about $1000. He even makes sure the sure grip isnt warp from the factory. If you decide to go Dana and want to get rid of the 489 pumkin, I would be interested in it, I plan on going to 4:10 and you can't get them for the 741 case,but I would keep the 8 3/4. :pop :pop :hungry :hungry
PostPosted: Sat Jan 12, 2013 9:53 pm
If your driving the Bee on the streat stay away from a spool. I have an Eaton posi unit that works perfect in the Burnt Orange RR.
PostPosted: Sat Jan 12, 2013 10:23 pm
Rhett thanks for the reply. I have an extra 489 center section if you need it let me know. Ralph, is the eaton true trac the unit that you have? I have heard and read really good things about that unit, good on street, doesn't clunk in and out and is very good so far as strength on the track.
PostPosted: Sat Jan 12, 2013 10:26 pm
Yes it is.
PostPosted: Sun Jan 13, 2013 10:07 am
Ralph thats the unit without clutches, it uses gears to lock right?
PostPosted: Sun Jan 13, 2013 10:44 am
Correct Rhett it has no wearable parts in it.
PostPosted: Sun Jan 13, 2013 11:10 am
That is the unit I'm going to go with ! Summit has them for about $530
PostPosted: Tue Jan 15, 2013 8:02 pm
I bought the Eaton True-Trac for my 489 case from Doc Diff last spring for $510, along with a 3.73 ring & pinion, u-bolt yoke, crush sleeve eliminator, bearings, seals, etc, it was just north of $900 total. Shop prices first then call Doc Diff and tell him what you found. As others already said, he was great to deal with. Good luck.
Kevin
PostPosted: Wed Jan 16, 2013 5:38 pm
:agree
check out DTS Custom Services 1.866.594.6192
http://www.dtscustom.com
B-body Dana 60 all new with your choice of axel ratio
$2200.complete diff. without brakes
$375. brake kit
$200. shipping aprox.
PostPosted: Sat Jan 19, 2013 10:17 am
Thanks for all the replies and info !! I spoke with cass ( dr. Diff ) and he was very nice guy to deal with. Going to stick with. 8 3/4 and run the tru trac
