It is currently Sun Jul 06, 2025 2:43 pm
 Post subject: Flying ryan
PostPosted: Fri Oct 26, 2012 7:40 pm
Ryan ran a 10.78 1.65 60' today at a track rental at lvd
Congrats ryan, you got it going!
 Post subject: Re: Flying ryan
PostPosted: Fri Oct 26, 2012 7:41 pm
And at 127 mph!
Amazing et at that mph on these tires!
PostPosted: Fri Oct 26, 2012 8:08 pm
PostPosted: Fri Oct 26, 2012 10:39 pm
Thanks Ted..that was fun...texting people while in staging waiting for them to sweep up imports not quite as much fun. The traction took out a couple domestics too...
Air started real close to last sundays event..
Track prep was killer...Lvd crew did a great job as well today
1st pass 11.07@127.95 1.85 60 foot just as ran Sundays final 10:29 am DA 869 feet
2nd pass 11.07@127.91 1.83 60 small shock adjustment 11.01 am DA 1085 feet
3rd pass 10.84@129.09 1.73 60 foot 11.54am DA 1003 feet I left harder+carb+timing adj.
4th pass 10.61@128.16 1.57 60 foot 1:00 pm DA 1173 with 28x9 slicks ! Not legal lol
5th pass 10.64@127.63 1.59 60 foot 2:00 pm da 1585 with 28x9 slicks shaking like mad
6th pass 10.89@126.79 1.73 60 foot 3:06pm DA 1672 back on treaded bias plys left harder
And last but not least ...hot lapping it to make one more pass...8 minutes later without stopping for anything but air pressure check....on treaded bias plys....
7th pass 10.78@127.01 1.659 60 foot 67 degrees DA1660 left matted track was hooking unreal..tires had a layer of sticky rubber on them..I think that's the best I had ever seen traction wise at lvd...so much rubber on the tires that they left a rubber path on my trailer floor pulling in!
Way fun ! Worked my but off to get all those passes And make some changes plus keep track of everything.
PostPosted: Fri Oct 26, 2012 10:46 pm
....on that 3rd pass 129.09 and 103.20 in the eighth!!! .I had leaned it down a little ...air got worse after that could of leaned down a bit more possibly..
PostPosted: Sat Oct 27, 2012 9:47 am
Those are some great numbers Ryan :aok and to run a 1.65 60' on treaded tires vs 1.57 60' on slicks :drinking looks like you got it dialed in real good! congrats!
BTW did you scale the car there?
PostPosted: Sat Oct 27, 2012 7:39 pm
Great to see. Way to go :drive also good to see a bow tie turning those times
PostPosted: Sun Oct 28, 2012 1:07 pm
3689 on the 10.78 pass...I'm 205 with clothes/helmet? Wish had some video to see how it looked.
PostPosted: Sun Oct 28, 2012 6:04 pm
3689 was with me in it..
