 Post subject: What clutch are you guys using?
PostPosted: Sun May 13, 2012 3:53 pm
Well good day yesterday but what I have been feeling for awhile my clutch was slipping. I was using a ram power force. I drive my car on the street also. Maybe 20k on it at the most. I would like to get more life at of a dual purpose clutch. Any suggestions on what to use that will hold up on the street and strip
 Post subject: Re: What clutch are you guys using?
PostPosted: Sun May 13, 2012 4:37 pm
I use mcCleod behind my hemi road runner but have not raced regularly with it...street use.
1968 Olds 4-4-2, 455, 4 speed
1968 Dart, 383, Auto, 3:91s
PostPosted: Sun May 13, 2012 7:50 pm
With those tires, i would say any clutch would be fine dom.
I had stock stuff in my LS6 chevelle when i was running it!
Besides a little slippage prob helps! Lol
PostPosted: Mon May 14, 2012 7:08 am
I use a Center Force dual disc with centrifugal weights. Very nice on the street,easy pedal but as rpm increases so does clamping force.
PostPosted: Mon May 14, 2012 9:51 am
Center Force dual friction disc is the only way to go. Don't make the mistake of not using a Center Force dual friction disc .
PostPosted: Mon May 14, 2012 1:52 pm
Torque converter heheheheheheh :runaway :moon :pop :stir
PostPosted: Mon May 14, 2012 5:04 pm
:sick :sick :sick :sick :nuts :nuts :nuts :off funny :rock
PostPosted: Tue May 15, 2012 6:26 am
Dom, I started out with a center force dual friction, then switched to the ram set-up, may try the turbo-hydro after I get my $h!t togehter....The problem I found with the center force, it engauged way too high for my liking, no matter how I adjusted it!!!
PostPosted: Tue May 15, 2012 2:28 pm
Mike, are you saying what I think you did? Say it ain't so! Don't put a slushbox in the blue beast. :(
PostPosted: Tue May 15, 2012 2:43 pm
I agree. :drive To me there is nothing like the pure violence of slamming gears. :gears Auto's are so pedestrian :sick
PostPosted: Wed May 16, 2012 9:40 am
How long did the clutch you have last? I would go simple HD GM with a good flywheel. Mine is still going strong after 100 plus runs with 427cu in in a 4200 lb car. Unless you plan on going to big cu. in. Why over think it?
PostPosted: Wed May 16, 2012 3:39 pm
Good point hal, theres more to gain with the flywheel than the clutch!
I would get a light weight flywheel and find lightest clutch assy!
PostPosted: Wed May 16, 2012 9:49 pm
True. My point is the last clutch maybe had 50 passes on it and about 20k miles. I can't say the ram clutch setup really lasted that long. I am still going to keep the flywheel which is sfi rated by Ram. But from this board and yellow bullet the consensus is center force or McLeod
So I just want to ge the best bang for my buck. I have been having some good progress and just want to keep it going
PostPosted: Thu May 17, 2012 9:41 am
I would stay away from a light aluminun flywheel in Dom's case. Not the lightest car with limited torque could be bog city, even with small tires.
PostPosted: Thu May 17, 2012 8:18 pm
I agree. Aluminum I will keep away from since I drive this regularly on the street. Also the fact my flywheel is only 3 years old and is sfi rated.
