It is currently Sun Jul 06, 2025 10:31 am
 Post subject: Welded Mufflers (What are they?)
PostPosted: Mon Jan 25, 2010 2:48 pm
Can you define what welded mufflers are? Are Flowmasters 40 series considered welded mufflers? Just trying to understand what's good to use.
Thanks,
Scott
 Post subject: Re: Welded Mufflers (What are they?)
PostPosted: Mon Jan 25, 2010 3:40 pm
A welded muffler is a Pypes, Flowmaster style muffler. The case is welded instead of a crimped case.
In the last year or so, Pypes came out with a welded muffler that looks stock. It has an oval case, very nice piece :aok . I have them on my HP2 Belvedere I.
4.04 Mufflers must be stock looking in design (Welded mufflers not encouraged). Maximum muffler inlet and outlet is 2.5”.
PostPosted: Fri Oct 21, 2011 3:09 pm
Looking for the best flow through muffler that fits the rules. :hungry
I think my dyno max super turbo are hurting me.
PostPosted: Fri Oct 21, 2011 3:32 pm
I would go with the Pypes mufflers and take the points hit. It is the best muffler available and looks stock.
PostPosted: Fri Oct 21, 2011 4:59 pm
I agree w ralph(finally)
I used to be that welded looked totally race!
But alot of them now are very neat, and oval as opposed to square with rounded edges!
I just changed from the cross flow i Had to two welded!
Didnt see more mph last week, but i think it sounds more mellow!
Definitly ditch the turbo mufflers :aok
There are some good offerings from borla too, that are oval, strait thru, and look pretty stock
PostPosted: Fri Oct 21, 2011 5:08 pm
Probably the best crimped style non welded muffler is these
http://www.dynomax.com/mufflers.php?muffler=ultrafloss
17283 is a common 2 1/2" configuration that works well on most cars..side in center out. They are "straight" through with perforations with some sound absorbtion material.
PostPosted: Fri Oct 21, 2011 6:08 pm
Thanks I had just come across the Dynomax ultra flow, which seemed to fit the bill, when I thought I'd ask. Jeff who spec my cam told me they were probalbly hurting me, but until I saw an animation of the super turbo's flow I never figured it was so much of a restriction. :bow Two 180 degree turns
PostPosted: Fri Oct 21, 2011 6:59 pm
I think the dynomax are great
The problem with most test results ive researched on line is......
Who's doing the test!!
Just stay away from the turbo type or the chambered!
PostPosted: Fri Oct 21, 2011 8:22 pm
Thank you sir, I'm sure either one will be much better than my super turbo's, :drinking
PostPosted: Fri Oct 21, 2011 8:44 pm
Yes,
Btw, thanks for the video.... Stunning
To see
We never get to see our cars run!
So cool, keep up the good work, ..... And the editing Lol
PostPosted: Fri Oct 21, 2011 10:22 pm
Agreed on that video ..Thanks! I new my camber was off and nose was sky high but that tells me tons. The camber is skewed because car was 1 inch higher on pass side when aligned...when i reset rear springs so car didnt sit crooked it made the camber on driver side go in and pass side go out just from the tilt of the car! I also have way to much front travel and the driver side a arms is binding at full drop. i think it get stuck at full extension!
PostPosted: Fri Oct 21, 2011 10:48 pm
Yeah.....!!what he said :rock
PostPosted: Sat Oct 22, 2011 8:31 am
It doesn't look like the toe is changing that much at full drop. really packing some air under the nose. It seems to be an issue all the quick cars have.
