It is currently Sun Jul 06, 2025 10:15 am
 Post subject: Advice on building a fast 440 six pack hp manifolds cuda
PostPosted: Mon May 08, 2017 9:47 pm
I have a 1970 440 sixpack cuda show car. It ran 13 30 on street tires. I am now having a set of stealth heads, hp manifolds, and 6 pack intake fully ported. I need advice on the lower end. How big is to big for factory hp manifolds? Camshaft, stroke, etc? 3000 stall 410 gear 727. Thanks Rick
 Post subject: Re: Advice on building a fast 440 six pack hp manifolds cuda
PostPosted: Tue May 09, 2017 8:31 am
Sounds like a common build except for the illegal heads. There is no limit on size with manifolds. You may want to consult with Dwayne Porter on this, you will find his info in the friends area of our website. With 906 heads we have builds at 526CI go low 11's.
PostPosted: Thu May 11, 2017 11:55 pm
That's great information but I'm really hoping someone will share some cam specs and stroke on 440 base engine. Along with quarter mile or 1/8 mile runs. I went to order a cam but they recommend me stayin with my 509 cam I already have and that bigger stroke with hp manifolds won't give me gains. I'm kinda lost building a restricted engine.
PostPosted: Fri May 12, 2017 6:26 am
I'm sure one of the 6 bbl guys will speak to this but with my small engine I'm running a custom Scott Brown solid lifter cam in the .550/560 range. I'm pretty sure the better flowing set ups are well into the .600's.
PostPosted: Fri May 12, 2017 9:16 am
I appreciate your response. The 383 is running good.
PostPosted: Fri May 12, 2017 9:20 am
509 is old technoligy that doesn't work any more. Dwayne Porter or Scott Brown are the ones to talk to about cam profiles and grinds for what your looking to do. Give them a call.
PostPosted: Fri May 12, 2017 5:07 pm
Who did you call? Not very many people know or care to know what cam works with manifolds. It is definitely outside most people's comfort zone so they guess The people listed previously understand what we and you are trying to do. They also are very easy to talk to. Dwayne Porter patiently answered all my stupid question. I'm a small block guy, so no concrete numbers. I would be very surprised if you reached the max potential of the manifolds before the power reached an absurd level for the street without a HUGE! tire. In a sb mopar you run out of cast iron cylinder head flow before the 340 exhaust manifolds. With sb being 444ci Intake is more of a problem but not for you sixpack.
PostPosted: Fri May 12, 2017 6:21 pm
I spoke with Comp Cams and 440 source. If anyone has their phone number I would appreciate it.
PostPosted: Fri May 12, 2017 6:33 pm
http://supercarraces.com/Porterracing.html
PostPosted: Fri May 12, 2017 6:54 pm
Great thank you I will give them a call now.
PostPosted: Fri May 12, 2017 8:37 pm
Hi I've built manny 440 based stroker engine, 493, 526 CI for street and SuperCars. I currently have the quickest 6 pack 440 based automatic an 4 speed. Iif want my build specs drop me line at, william.atwood@snet.net
Home of The afxers
65 Plymouth A/FX 9.50@139 mph
1969 Hemi GTX 12.63@112 mph
Bill Atwood
http://www.afxer.com
PostPosted: Sat May 13, 2017 8:51 am
Awesome thanks.
