It is currently Sun Jul 06, 2025 10:27 am
 Post subject: 2013 SuperCar ShootOut Stock Appearing Rules Revision
PostPosted: Wed May 29, 2013 2:03 pm
Ralphs Rapid Transit LLC
Press Release May 29, 2013
DBA SuperCar Races
Factory Appearing Stock Tire MuscleCars
Rules Update: Removal of the wording “ No performance gain”
SuperCar Races continues to forge forward on its commitment to our racers, sponsors and fans, through our vision to Showcase All that participate in the SuperCar ShootOut. We give our racers a fair playing field for all to participate in, with one set of rules for everyone to follow. We committed our selves to be fair and consistent with our rules and judgments, creating exciting and competitive racing at every E/T level.
The Rules Committee, Advisory Board and I have decided to remove the wording “No Performance Gain” from rule 2.03 Cylinder Heads*: Cylinder Head MUST be of correct OEM casting, have correct original casting numbers and be of correct original OEM material. If using a factory correct Replacement Cylinder Heads* the following criteria must be followed. The use of a Factory OEM Replacement Cylinder Head* that has no performance gain over the original part number Cylinder Head is allowed.
The new rule will read 2.03 Cylinder Heads*: Cylinder Head MUST be of correct OEM casting, have correct original OEM casting numbers and be of correct original OEM material. If using a factory correct Replacement Cylinder Heads* the following criteria must be followed. The use of a Factory OEM Replacement Cylinder Head* must have the correct Replacement OEM part number and must be approved by the Rules Committee. The original part number Cylinder Head is allowed without approval.
Approved Heads for 2013
GM Head 12363408 (Casting number is 12363401)
GM Head 14011077 (
Chrysler- Mopar part # P5249824 No Freeze Plug end. casting # 24065518-M
Mopar part # P5007494 No Freeze Plug end
We are excited to bring you this change. We feel this is a change that will continue to grow our series in the direction that keeps us grounded to our core values and the original intent of factory appearing Stock Tire MuscleCar Racing.
We appreciate all of the feedback given by the Rules Committee, Advisory Board, Racers and ask that you continue to use this website to voice your opinions, wins, struggles, and give us feedback on how we can make your racing series better.
Advisory Board
 Post subject: Re: 2013 SuperCar ShootOut Stock Appearing Rules Revision
PostPosted: Wed May 29, 2013 9:57 pm
I feel this is a much needed improvement to help keep racers on the track without going overboard, and allows racers to compete without breaking the bank or destroying valuable original restoration quality heads!
These are some heads that have been requested and approved after much research and deliberation! If you have a situation that needs attention i know supercars will do its best to help out while staying within the original intent of the factory appearing style of racing!
Good job!
PostPosted: Thu May 30, 2013 6:35 am
I think that was a fair decision for all you peeps with big blocks. Definitely see a cost savings while maintaining the spirit of original type castings
PostPosted: Thu May 30, 2013 11:40 am
PostPosted: Thu May 30, 2013 5:26 pm
Are these heads permitted for all big block Camaros, meaning 396 motors with the L89 option?
PostPosted: Thu May 30, 2013 10:26 pm
YES!
PostPosted: Thu May 30, 2013 11:48 pm
Far out...
