It is currently Sun Jul 06, 2025 11:07 am
 Post subject: Starting point tune
PostPosted: Mon Mar 10, 2014 8:36 pm
My 72' is pretty close to being ready to run, and be roadworthy. I am going to start with somewhere around 14-18 degrees base timing. (Vacuum advance disabled) I have a Moroso spring and weight kit installed with the heavy springs. (around 36-38 degrees total advance) Plugs are indexed, stock heat range - 44 I think?, .035" gap IIRC. Petronix Ignitor III with matching coil.
My SCR is 9.65:1 (measured) vs. the factory advertised 8.5:1. The DCR is 8.57:1
(For reference, I have a spare, untouched short block. I took some measurments and come up with 8.4:1 SCR and 7.365:1 DCR)
I am guessing around 3900-4000 lbs with driver and fuel. 3.73 gears, M21 close ratio trans.
Am I in the ball park with my timing and plug gap?
 Post subject: Re: Starting point tune
PostPosted: Mon Mar 10, 2014 8:59 pm
Seems in line, should start!
Im curious what your cranking compression is?
PostPosted: Tue Mar 11, 2014 4:26 pm
I'll have to stick a guage on it and see. I generally like to check all 8 cylinders with zero miles, then again after 800-1000 miles. All the calculators I have checked online say around 188 psi +/- 1-2 psi.
Users browsing this forum: No registered users and 1 guest
